HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 27006
Effect of aluminizing on E-glass fiber
Currently I am working on (Aluminized E-glass fiber)to check the mechanical and physical properties, I have bonded the aluminized E-glass fiber with polyester Norrpol 444-M888. Did the mechanical tests (impact +tensile+ flexural) and I had strange results. In comparison with Bare E-glass fiber,the bare E-glass fiber was stronger %53 than the aluminized E-glass fiber, my first conclusion was the aluminum did not have a good adhesion to the polyester. I would like to ask you if there is way to bond these fiber to improve the mech and phys properties. PS (I have used Epoxy and Twintax and didn't work so far). I thank in advance for any reply.
Osama ErrajhiComposite Material Researcher - Tripoli, Libya
Hi Osamai,
Am read your search but I want answer you if you can write your search by Arabic when Arabian people can raed your search.
Anis- Tripoli
Ed. note: Thank you, Anis, but this website can post only inquiries and responses that are in English. Sorry.
