Letter 26129
Economically getting chrome plating
adhesion on Hastelloy and stainless steel
We have been chosen to hard chromium plate two materials; one is a
stainless steel, and the other a nickel based Hastelloy. At this
stage I don't know the exact compositions or final heat treated
conditions, but I do know they are French alloys.
We trialled them by using the standard vapour degrease, grit blast
and reverse sulphuric/hydrofluoric etch, but as we all know, some of
these alloys can be very hard to properly activate. The result was no
adhesion after chrome plating.
Next we tried using a nickel strike and flash sulphamate nickel
plate in addition to the above, and it worked quite well. But we want
to avoid using this to keep our costs down. Does anyone have a
suggestion as to what cleaning and activation cycle we may employ
that will give us the good adhesion required, without having to
resort to the nickel underplating?
Trevor Rowlands
Materials & Processes Engineer - Melbourne, Victoria, Australia
Trevor,
Hastaloy is almost the same alloy like Inconel 648 and 718 thats
is a very difficult alloy to plate on. I have describe a method for
it in letter 12398. This method work
for me.
Anders Sundman
surface finishing engineer
Sweden
Prep as you have, Light reverse current etch in chrome tank. Big
hassle and expense is the big knife switch you will need.
Jon Quirt
- Minneapolis, MN
Trevor,
As a jobbing shop, I get hundreds of jobs that are "stainless" or
"hastelloy". The thing that we find always works is a good hydrogen
flush. If the alloy has a high chrome content(A bluish colour) then a
light etch first, if a high nicklel content(a yollowish colour) then
stright in the vat live. If your not sure of the voltage to flush,
Start plating at lowest posiable voltage, and turn up untill you see
the first bubbles appear, then turn up a 1/2 Volt every 5 minutes, to
the plating speed. On some of the Hastelloys you have to raise the
voltage above the plating voltage for a few seconds to 'strike' and
start them plating.
Regards, Steve ;-)
PS. For practical demonstrotion send air tickets to.....
Steve Kelson
hard chrome plating - Cheshire, England
Would try activation H2SO4/HF using current 30-50 A/sq dm, and
then as Mr Steve Kelson suggested.
Cair Shishani
aircraft maintenance - Abu Dhabi, UAE
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- Post a new
question or inquiry on a different subject.
