HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 26128
Does Electroless Ni require post treatment?
+++A 2-3 microns thickness of Electroless Ni applied on Al sputtered layer (of about 3 microns thick)- does it require any post-treatment if the major object is to achieve high resistance to corrosion? If so, what is the adequate treatment?
Meirav ShahamFA engineer - Jerusalem, Israel, Israel
You did not specify what environment will this be exposed to. Also, what is your definition of high resistance to corrosion. For most commercial aplications a minimum of 12 microns is specified. The thickness you mention might work well but just for solderability purposes.
