Letter 26113
White streaks in anodizing due to uneven
blasting?
To Whom it May Concern:
I am anodizing per
Mil-A-8625 [link is to spec at TechStreet] Type II,
Class II black on 6061 aluminum which prior to anodizing is being
powder glass bead blasted at the customers facility. After anodize
the part becomes patchy with white streaks where it appears the
blasting is uneven. I have tried varying my Alkaline Etch time from
15 seconds to 2 min. with no improvement. If you would have any
solutions on this matter it would be appreciated as it involves large
quantity orders and several different jobs.
Respectfully,
Tim
Timothy Furrer
Anodize Shop Manager - Chino Valley, Arizona, USA
This is VERY simple, follow this instructions :
1) etch on your caustic for 10 sec
2)20 sec deox
3)aprox. 45-60 sec in ABF sol.
4)flash anodize for 10 min.
5)GO BACK TO YOUR CAUSTIC ETCH, STRIPPING THE ANODIZE
6)deox the same than before 20 sec.
7)go back to your ABF sol same time
8)anodize for normal time w/your die and seal
And thats how you get rid of the streaks from any blasting
Sergio G.
- Oxnard, CA
Poor Bead Blasting is poor bead blasting. Excessive pressure and
uneven blasting produces uneven appearing parts. The solution is to
decrease pressure, use the proper media and blast with even movement.
Aluminum will "burn" otherwise. Few people know how much art is
involved in cosmetic beadblast. To correct the problem a striplight ,
even beadbast and anodize.
Good Luck.
Bill Grayson
- Santa Cruz, CA
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- Post a new
question or inquiry on a different subject.
