Letter 26102
Improving our citric acid passivation
process
We do cold passivation of components in citric acid. However we
use De-mineralised water to do the passivation. Final wash is also in
DM water. Is DM water harmful to the passivation film, should we use
regular tap water instead? Also is hot passivation a better option ?
We do get a failure rate of approx 3 % in salt test doing the above
passivation procedure. Moreover we observe that the components that
have some sort of cut or pit tends to catch the rust. How can we
passivate so that these components also do not rust.
Jack Steven
engineer - Istanbul, Turkey
The use of DM water is critical to a proper passivation. It is
acceptable to use tap water for intermediate rinse steps but I don't
recommend it unless the cost of DM water is a prohibitive factor. I
would also suggest an elevated temperature. ASTM
A967 [link is to spec at TechStreet] and
A380 [link is to spec at TechStreet] specifications
will have the information your looking for. I would also recommend
polishing any pits or irregular welds before passivation. Hope that
helps.
Joseph Lockrem
chemical cleaning - Indianapolis,Indiana,United States
Thanks but I read an article saying that Deionised water ( which I
assume is same as Demineralised water) strips the chromium oxide
layer that forms due to passivation. Is that true? Also we do polish
the pits but the pits are in microns, not even visible by naked eye.
How do we make sure that the citric acid passivation takes care of
such minor scratches or pits?
Jack Steven
- Turkey
We use steam distilled water at a conductivity or 20
microsiemens/cm2 or less for passivation baths and rinsing. Keep in
mind that the passive layer does not form immediately upon rinsing.
The film requires some time (minutes to hours)to form depending on
temperature, environment, and drying method. The chlorides and iron
in tap water would deposit on the cleaned surface and could cause
problems later. I am less capable of advising you on the pits or
inclusions in your welds. We recieve parts that are polished to a
sanitary finish and have no problems with "rust". An elevated
solution temperature and longer immersion time may help. A nitric
acid solution may be better suited to your application. I would refer
to the ASTM A-380 and A-967 specifications for advise on chemical
selection.
Joseph Lockrem
chemical cleaning - Indianapolis, Indiana, United States
Citric Acid removes iron from the surface and does not oxidize the
nickel and chromium. Nitric Acid removes the iron AND controlled
oxidizes the nickel on the surface so that the nickel will not
continue to tarnish.
Passivation means contrlled oxidation.
I use De-I in my A-967 passivation procedure largely for removal
of chlorides in tap water. If De-I strips the chrome oxide layer,
what's the problem? That's all part of passivation. It may lead to a
more uniform passivation once the cleaned part is exposed to air.
After years of using Nitric, I now use Citric style passivation. I
feel the rinse is more critical due to the mild nature of the citric
to dissolve the surface iron.
Last year, I ran some tests at one customer's corporate
metallurgical lab. They wanted to see if A-967 chelant passivation
was as good as the old A-380 Nitric. We contaminated test coupons of
317L and applied both methods-Citric vs. Nitric. Both passed the
copper sulfate test with the exception of one tiny spec on the Citric
panel. It seems they stamped the coupons for identification purposes
using mild steel punches. One tiny spec of iron embedded in the
impression of the letter remained after the chelant passivation. To
me, it reinforces the importance of rinsing under pressure. I feel
that spec may have been dislodged with a higher pressure rinse.
I clean large equipment using a spray approach rather than bath
applications. I use at least 1500psi and prefer 3000psi for the
rinse. Is a pressurized rinse possible for your application? Heat is
also big plus.
Todd Turner
- Monroe, LA
Deionized water is always preferred for rinsing if it is available
and cost effective for the operation because it does not allow
contamination of the surface with chlorine and other ions. It also
will give you a spot free surface if your final rinse is clean.
Passivation with citric acid will always give you a better passive
layer when the right formulation and procedure is used. The best
corrosion resistant oxide layer can be formed using citric acid
formulations and multiple deionized water rinses. If you need help
with your particular alloy let us know. If you read ASTM A-967 it
gives you the definition for what passivation is. A-380 is not a
passivation specification and should not be used for that. It is a
recommended practice. A-967 is the ASTM passivations specification.
A-380 has many good practices for cleaning, pickling, etc. and does
contain some ideas for passivation, but is not a specification.
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- Post a new
question or inquiry on a different subject.
