Letter 26098
Non stick coating on SS Tube ID
The company I work for is faced with the following problem.
1.Equipment and method to spray reliable and consistently uniform
coating of nonstick PTFE liquid on I.D. (50 mm onwards) of 304
stainless tube. length 300 plus.
2.Reliable method of removal of PTFE coating for
recoating--preferably solvent method.
Advice on the above most welcome.
N.G. KRISHNAN
- BANGALORE, KARNATAKA, INDIA
Mr. Krishnan, hopefully a vendor with a commercial interest in
solving your problem will contact you in hopes of selling you their
product.
But in terms of advice, at this site you usually receive in
proportion to what you give, and nobody can learn anything from your
posting. Please try to flesh it out with what you have learned from
your own experience. ("We tried xxxxx with xxxxx, but the problem
it gave us was....") Thanks!
finishing.com
Brick, New Jersey
Once the Teflon is cured, you cannot remove it by solvent. Teflon
is used because it is inert to most chemicals. We are Licensed
Industrial Applicators for Dupont and we use other methods for
removing the coating. What kind of accuracy are you looking for in
the coating thickness?
Perfluorinated kerosines will remove Teflon at high temperatures.
Dinesh
- Chennai, Tamilnadu, India
Your application is quite possible but we would like a better
description of your process needs.
Thank You,
Edward Curran
- Houston, Texas
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- Post a new
question or inquiry on a different subject.
