HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 26068
Cleaning carpets of green copper corrosion drippings
I have read the FAQ's and did not see this question. We have a situation where the green corrosion from copper pipes has dripped on the carpet. I am looking for the best way to remove this material. This will be performed by a professional carpet cleaner.
Thank you in advance,
Bill Yeadoncleaning - Westerville, Ohio
These copper salts should readily dissolve in even mild acids. I'd suggest trying white vinegar followed by soapy water. Good luck
