HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 26062
Powder peels from aluminum rims at bolt area
+++Dear Sir,
Re. Powder Peel Off at Bolt Area
We are a manufacturing company of Aluminium Rims and Aluminium Actuators . The problem we face is powder paint peel off at the bolt area. The powder is Polyester TGIC Free an the Curing Time is 200 Deg Celsius at 10 Minutes. If the Temperature is set to 240 Degree Celsius the Colour becomes Darker. Please Advice Us. Your kind cooperation is much appreciated.
Thank You, Yours Sincerely,
Batummalai VellayanEngineering Officer in Alloy Rim and Aluminium Product Manufacturing Industry - Seremban, Negeri Sembilan, Malaysia
Dear Sirs,
Your question informs us that the defect is confined to the bolt area.
As a manufacturer of powder coating materials, we would investigate why this is and experiment to eliminate the probable causes.
1) after your normal cleaning process once again clean with a solvent (a) Xylol [linked by editor to product info at Amazon], (b), MEK / methyl ethyl ketone [linked by editor to product info at Amazon], (c) boiling water. Clean only a few bolt holes leaving the remainder untouched. Use the different solvents on separate components. Then powder coat as normal. Test for adhesion areas around x-clean and normal.
As described your problem appears to be one of cleaning and finding the right method. Check if the lubricant you use for creating the bolt holes does not contain silicone, some do and you will have to find a non-silicone type.
regards
Terry
Terry Hickling Martex Paints Ltd Birmingham, United Kingdom |
