finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 26061
Need brazing material /filler that can be electroplated
I have a problem to find a filler or brazing material to be added on aluminum casting; this material must be a metallic material since end product of this aluminum casting is nickel-plated. I've tried using such pastes but I guess it's non-metallic since while electroplating it creates a white spot on that filler area (which it means that the filler is not working with the nickel plating). Could somebody give me advice?
Danny
engineer - Jakarta, Indonesia
November 8, 2011
Hi, Danny.
"Lab-metal [linked by editor to product info at Amazon]" is recommended in letter 3801; "All Metal [linked by editor to product info on Ebay]" is recommended in letter 9167. Both probably require additional treatment like zincating before nickel plating. Good luck.
finishing.com
Brick, New Jersey
