Letter 26051
Jorge,
Often mufflers can have stain or a blue shiny effect after the engine first has started, that can be related to the ignition is wrong at the engine, i.e., the temperature is too high.
Anders Sundman |
The bright (as deposited) nickel under the chrome always turns yellow-brown-black under heat and the muffler does get hot. The sulfur bearing brighteners are codeposited or occluded and the sulfur turns color. I have plated many motorcycle exhaust pipes with pure nickel, buffed, then chrome plated and never had the nickel turn color under the chrome.To avoid this problem you must use a PURE nickel that is deposited dull and then buffed before chrome plating. A pure Watts formulation without brighteners or a pure Sulfamate formulation without any sachrin should not turn color under the heat of a muffler.
Robert H Probert Editor's
note: |
Save
This Page (why?) - Home - ©1995-2009 finishing.com
