Letter 26048
Alternate finish needed for blued spring
clips
I currently have a rust issue with a 0.010" thick cold rolled
annealed spring clip. It is natural blued after hardening. These
parts are used in a chassis that is installed in a CO environment;
not exposed to extreme elements. Our customers have advised these
clips are rusting after they have been in the field for a period of
time. I am looking for an alternative finish that will prevent this
without changing the integrity of the heat treating process. Please
advise your recommendation(s). Thanks in advance!
Tory Giammanco
Principal Engr. - Telecom - Rolling Meadows, IL, USA
These oxide finishes offer little if any corrosion resistance. You
may need to do something more radical like zinc plating them, but
since the exposure is mild you could try a water soluble wax or
lacquer, or a light oiling of your blued finish first. Your local
plating supplies distributor should be able to suggest such a dip.
finishing.com
Brick, New Jersey
With Zinc plating you will have to consider hydrogen
embrittlement. Wax, oil or simple dip coat paint are easy options.
Ecoating is another option you can try.
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- Post a new
question or inquiry on a different subject.
