HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 26047
Passivating steel danglers
+++We do barrel-electroplating.(Nickel, Copper etc.) We use steel danglers in barrels. (Not St. Steel) >From time to time we remove plated deposit from danglers to reuse dangler again. We remove coating by hammering them.
Questions:
1) Is there a way to passivate the steel dangler so that removing the deposit becomes very easy?
2) Is there an easy way to remove the deposit instead of hammering the danglers?
Thanks a lot for replying to these questions
Pravin AagashePlating Supervisor - Bombay, Maharashtra State, India
You could try electropolished stainless steel danglers.
