Letter 25112
Do cutting tools require recoating after
sharpening?
Should a cutting tool that has been coated, be recoated after
resharpening.
David Martin
Machine shop - Hartland , Wisconsin, USA
If the remaining coating is intact, it normally does not need
recoating. Chrome or TiN are very hard coats that reduce wear. The
tool steel portion will actually wear a little faster, so tend to
keep a sharp cutting surface longer by constantly keeping a sharp
edge of tough chrome. On the rest of the tool, the coating just
facilitates the chip removal.
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- Post a new
question or inquiry on a different subject.
