HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 25110
Aluminum vs. 316L SS for exhaust duct
Kindly let me know which of the two metals namely, Aluminium & SS316L will be most suitable for exhaust system ducting under following conditions of exhaust gases. Temperature - 35-40 deg C Pressure - 25 -30 mm of water column Gas composition - Mixture of CS2 & H2S ( CS2-1450-1550mg/nm3 & H2S- 450-550 mg/nm3) + some water vapour.
Raghavendra- Hyderabad, Andhra Pradesh, India
