Letter 25102
CAN WE USE A LASER FOR GOLD
POLISHING?
HELLO TO EVERY ONE WHO READS THIS MAIL.
I AM AN ENGR. STUDENT. I HAVE A TECHNICAL QUESTION ON A FINISHING
PROCESS. PROBLEM:- IF I WANT TO FINISH (POLISH SURFACE WITH HIGH
SURFACE FINISH) SMALL GOLD PIECE HAVING DIMENSIONS 6 MM-LENGTH, 2
MM-WIDTH, AND 0.5 MM-THICKNESS . TO FINISH SUCH SMALL PIECES AT HIGH
VOLUME IN A SHORT TIME, WHICH METHOD IS SUITABLE?. PLEASE COMMENT ON
METHODS YOU ARE AWARE OF. CAN WE USE LASER BEAM FOR FINISHING GOLD
COMPONENT?
I NEED YOUR SUGGESTION ON PROBLEM.
MAHESH PADAMAKAR JAGTAP
STUDENT - JALGAON, MAHARASHTRA, INDIA
You can use a CO2 laser system to perform on almost every
material, including metal and non metal parts. The only limitation
might be the reflectiveness of the piece. (Those gold little pieces
you mention mustn't be too much reflective so that the light could
affect the material surface). The typical spot diameter is of about
0.2-0.3 mm but you can des-focalize it to get a bigger size, being
able to get a feature of 2 or 3 mm.
Sergio Barrio
- Spain
Dear Reader, please --
- Answer or follow-up on this
subject (in non-commercial
fashion).
- Post a new
question or inquiry on a
different subject.
- This is a
monitored
forum. If you spot broken links or
obsolete info, please advise!
