finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 25091
Highly Reflective / High Temperature Paint
I am looking for a paint that has high reflectivity (like chrome), can operate in temperature environments at ~250 degrees F, and I can spray for my application. Aluminum colored paints are not reflective enough.
Roger Johnson
Mechanical / Aerospace - Cary, North Carolina
You might try a paint with vacuum metallized aluminum pigment in lieu of a standard aluminum flake. Most industrial paint companies should know what you are asking for when you contact them. The vacuum metallized pigment can provide highly reflective properties when incorporated into the right binder for the application. Good luck.
Michael A. Koons
industrial coatings - Willoughby, Ohio
I am searching for a paint which is highly reflective with reflectivity(0.95-0.99) compatible over a aluminum surface. It is for industrial application.
Give with company details.
S.Annie
- Banglore, Karnataka, India
