HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 25061
Can bright dip help in soldering/ brazing on to copper bar?
We braze Silver Cadmium Oxide tip onto copper bars and prior to brazing if the surface free of contamnition, then the solder flows freely. I have told to bright dip. Also after we mfg the part we would like the parts to look clean as well as have a longer shelf life i.e not to tarnish or oxidize.Was told to bright dip. Can you advise?
Zul KassamMfg. Of Electrical Contacts - Toronto, Ontario, Canada
What is the easliest and simplest way to bright dip copper or brass bars? This is to stop oxidation or tarnishing.
Zulmfg of copper contacts - Toronto, Ontario, Canada
An oxidizing agent is needed for bright dipping. Nitric acid is a possibility, but sulfuric acid plus stabilized hydrogen peroxide is very popular for that purpose. After bright dipping the bright appearance can be prolonged by application of sodium benzotriazole.
