HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 25029
High emissivity coating for textile surfaces
Dear sir,
I am looking for a coating with high emissivity factor that can be coated on to a textile surface. High emissivity factor , I understand relates to the amount of incoming radiation that is absorbed by the body as compared to a totally black body. Therefore if I seek to increase the UV or heat absorbtivity and increase the IR radiation given out would the use of a high emissivity coating (like oil paints, zirconium silicate, etc.) work? Are there coatings that have high emissivity that are not black or dark in colour?
Usha S [last name deleted for privacy by Editor]Textiles - Nettetal, Germany
