Letter 25017
I don't fully understand what you are proposing, but even with my own lack of artistic sensibility, I'd have to agree that such an assembly will probably look "unattached" unless it includes screws that quite obviously connect the copper strips to the stainless strips. Artists would probably laugh at me but I think copper screws where the stainless overlaps the copper and stainless screws where the copper overlaps the stainless might look okay.
You can tig weld stainless steel to copper using a deoxidized
copper filler rod. We have done this to a sample piece we intend on
using stainless steel and copper for a up coming fountian we will be
building. We are also looking at incorperating stainless into our
hoods in the future.
Good luck
master coppersmith
Mark Murphey
Mark Murphey
- Indianapolis, IN
+++++++ We are getting our kitchen redone and I would like to make a copper range to cover a built in vent. (at this time we are considering a Faber stainless insert) I saw an article in a woodworkers magazine years ago about copper cladding a plywood range hood. That is sort of what I had in mind. I can work with copper a little. If anyone could direct to a magazine, or could provide a little advice I would appreciate it. Richard Truelove
+++++++ Stainless steel can be soldered. In fact, it solders almost as clean as copper, much better than galvanized steel, tin, terne, or lead coated metal. Might be a little late, but I figured I'd throw my advice out there. Aaron Vogler
Dear Reader, please --
Save
This Page (why?) - Home - ©1995-2009 finishing.com
