HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 24120
Corrosion Rate of Alodined magnesium
Currently we have a PDA frame made of Magnesium AZ91D finished with Alodine 5200 coating.
Will like to find out what is the corrosion rate when coated with Alodine 5200.
electronics - Singapore
How are you! Alodine 5200 is non chrome conversion coating agent. I did test before. I found poor result of salt spray than generally chromate coating. I think non-chrome conversion coatings on Al,Mg have a lower resistance than chromate coatings.
SE DO JANG- Korea
Jeremy,
What is the environment for this component? As Mr. Jang said, Alodine 5200 does not provide good resistance to corrosion in a salt spray environment. However, it may provide adequate corrosion resistance in normal ambient environments (humid air, low salt, etc.). Alodine 5200 is usually used as a pretreatment prior to painting. The combination of Alodine 5200 with either a cathodic epoxy electrocoat (e-coat) or a polymer powder coating (epoxy or polyester) can provide resistance to corrosion in salt spray environments. Damage to the relatively thin e-coat layer can produce premature corrosion. Thick powder coatings usually provide much better corrosion resistance than just e-coat.
Toby Padfield- Michigan
