Letter 24114
Robert H Probert Editor's
note: |
Have a 3 stage rinse after Plating Sn from MSA bath followed by Hot-10% TSP (Trisodium Phosphate [link is to product info at Amazon]) dip, rinse and finally rinse with Hot DI water. This will help remove staining caused by tin plating solution.
Good Luck...
Karthik
- Norwood, Massachusetts
Great information on the Tin Discoloration.
I have similar issues with discoloration (Yellow tint & black
stains) on parts that Tin is plated on Copper surface.
However, the discoloration always appears 2,3,4,5 months after the
production of the part. For this reason, I was wondering if anyone
knows of a Highly Accelerated System Test (HAST) that I can run after
the product is made to predict if the parts are going to fail
later.
I would like to use the test as a LOT acceptance Test.
I would really appreciate any suggestions you might have.
Gus Mavrogiannis
- Orland Hills, Illinois
January 13, 2008 Well I am back with lots more experience now after
posting my first question above. Peter
December 3, 2008 I think the copper base and plating tin over it will not work,because of copper oxidizes and migrates copper on the surface and makes the tin surface discolor.It will fail solderability and it doesn't pass 85/85 test.If you want to make it work you must plate nickel over copper,it will stop copper from migration to surface.It will solve a lot of headache.If you want your process non-magnetic than you cannot use nickel, but you can use palladium to protect your copper and than plate tin over the palladium.The process on the palladium is not easy,if you know the technic you can make it work. Good Luck, Duang
Bouphasavanh
Save
This Page (why?) - Home - ©1995-2009 finishing.com
