![]() (Cycles thru suppliers) |
Letter 24112
Gurvin Singh |
A PRE TREATMENT PROCESS SHOULD BE TAKEN CARE OF FOR CAST IRON COMPONENTS. A DESCALING BATH CONSISTING OF 200 GMS \ LTS OF CAUSTIC SODA AND 20 GMS \ LTS OF POTASSIUM PERMANAGNATE SHOULD BE USED TO DESCALE THE CAST IRON AT 70 -80 DEGREES CELSIUS.AFTER THIS THROUGH RINSING AND HCL ACID PICKLING WITH INHIBITOR AT 1% ON ACID VOLUME SOAKING FOR A MINIMUM PERIOD OF 30 MTS IMPROVES THE SURFACE. NOW KEEP 1% CAUSTIC SODA SOLUTION AT BOILING TEMP. 70 DEGREE CELSIUS AND THEN GO TO THE BLACKENING BATH WHICH CONTAINS CAUSTIC SODA 650 GMS \ LITRE , SODIUM NITRITE , 200 GMS \ LTS SODIUM NITRATE 150 GSM \ LTS AND SODIUM CYANIDE 1 GMS \ LTS. THE TEMPERATURE SHOULD BE 135 - 145 DEGREES CELSIUS WITH EFFERVESCES BUBBLING OUT IS THE RIGHT TIME TO INTRODUCE THE COMPONENT FOR BLACKING AFTER 1% CAUSTIC HOT DIP. DON'T WIPE OFF OR RINSE AFTER BLACKING ( OXIDISING ) . FINALLY APPLY DIESEL 25% + CUTTING OIL 75% DIPPING SHALL IMPROVE THE SURFACE TO GIVE A SMOOTH AND BEST FINISHING. THERE IS NO NECESSITY FOR THIS OILING BATH HEATING.
C PRAKASHAM
chemical company - KOLKATTA, CHENNAI, INDIA
Save
This Page (why?) - Home - ©1995-2009 finishing.com
