Letter 24108
SIMPLIFIED PRETREATMENT FOR POWDER COATING
I'M USING THE SEVEN CHEMICALS TO CLEAN THE MATERIALS BEFORE
COATING THEM.
I WANT TO KNOW IS THERE ANY NEW CHEMICAL FOUND THROUGH WHICH I CAN
INCREASE THE PRODUCTIVITY AND ALSO REDUCE TIME AND ALSO INCREASE
QUALITY.
THANK YOU VERY MUCH
DILIP ISHWARBHAI PANCHAL
POWDER COATING - BARODA, GUJARAT, INDIA
Dear Mr. Panchal,
If you are using the seven stage pretreatment, we presume you are
using zinc phosphating. Now, if your component contains rust, then
this method is necessary.
In case the components are without rust, and the customer does not
have a requirement for zinc phosphating, then there are single stage,
no-rinse single tank pretreatments in the US and Europe which can do
pretreatment in one stage.
However, they have not taken off well in India, primarily due to
rust problem.
Sandeep Kundra
manufacturers of metal pretreatment chemicals - Bombay, Maharashtra,
India
Where can I find out more about these one step pretreatments that
are used in Europe for rust free mild steel?
Jerry Jaksha
- Rio Rancho, New Mexico
October 17, 2009
Hi, Jerry. All of the manufacturers of pretreatment chemicals,
like Chemetall, have
one-step pretreatments in their repertoire.
finishing.com
Brick, New Jersey
