![]() (Cycles thru suppliers) |
Letter 24102
Ken Vlach |
As Ken says, ASTM A380 should not be used as a passivation specification, and QQ-P-35 has been canceled. The 3 consensus specifications used at this time, and that should be used for all specifications of passivation are:
ASTM F86 [link is to spec at TechStreet] for
Orthopedic implants
AMS-2700 [link is to spec at TechStreet]for Aerospace
ASTM A967 [link is to spec at TechStreet] 01e for
all other applications
There are other in-house specifications for some companies.
A-380 has a lot of excellent recommendations on general cleaning etc. of stainless steel, but should never be used as a passivation spec.
AMS QQ-P-35 is being canceled in favor of AMS 2700B (at the moment it is version B)
You should never ask for "standard passivation" on imports. Always specify exactly what you want-- e.g. ASTM A967 01e, Citric 4 or AMS 2700B Nitric 1. If you do not specify, they can use whatever they want, even ways that are not in any of the specifications! What is standard to you may not be standard to them.
Save
This Page (why?) - Home - ©1995-2009 finishing.com
