finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 24058
Removal of heavy hard chrome plating from steel cylinder liner
Hello, I'm trying to remove approx. 6-8 thou of hard chrome from a cylinder ID with an area of approx. 80 in ^2. The chrome is plated to a thin steel liner which in turn is pressed into an aluminum body. I would like information on the most "cost effective" way of stripping the chrome with the intent of re-plating. I would also like to minimize any damage to the part in terms of etching or other.
Marc Couture
an engineering company - Winnipeg, Manitoba, Canada
If you are going to replate it, let the plater do the job. There are at least four alternatives and a conventional chrome shop normally has two. Honing the part in a machine or reverse the cycle in the chrome bath. Also immersion in HCl or anodic treatment in NaOH will strip the chrome, but exposed aluminum will also suffer in both cases and the waste produced will require regulated disposal.
Guillermo Marrufo
Monterrey, NL, Mexico
