(Banner at right cycles thru suppliers of electroless nickel plating services) |
Letter 24033
Todd Osmolski |
Probably, an adhesion bake at an excessively high temperature oxidized the surface. Adhesion bake on aluminum should be at 375 F for non-heat-treatable alloys, or 250 F for heat-treatable alloys (Mil-C-26074 [link is to spec at TechStreet]E, Classes 3 & 4, respectively). A straw colored tarnish suggests a hardening bake > 600 F, as performed on steel (Class 2).
Ken Vlach |
The symptoms you describe indicate that the aluminum was not electroless nickel plated but rather it s anodized and dyed gold. Come back with more information. Electroless Nickel freshly plated, especially only after a few days WILL conduct. Anodizing is insulative.
Robert H Probert Editor's
note: |
Save
This Page (why?) - Home - ©1995-2009 finishing.com
