HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 24022
Hydrofluoric Acid Contamination Treatment
+++We are having 2 to 5% of HF contamination in our effluent water, which we want to remove/convert and reuse the same.
Welcome all your suggestions
- PONDICHERRY, Pondicherry - Union Territory, India
Your question is a bit vague, Mr. Annadurai. 100 gallons per week or 100 gallons per second? Where is it used, how did it get the hydrofluoric acid in it, what else is in it, in what way do you want to re-use it? Thanks!
Mr Annadurai,
The solution to your problem is to find a local company that installs Reverse Osmosis equipment. Tamil Nadu State Pollution Control Board has a consultancy advisory too in Chennai.
Asif Nurie Atlanta Global New Delhi, India |
