HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 24021
Chemical ratios for QQ-P-35 passivation of stainless steel
We want to develop a small in-house passivation process to be used for limited qty parts (clinicals).
I have ASTM A967 [link is to spec at TechStreet] but would like a free copy of qq-p-35 so we can get the chemical concentration numbers. We already have a lab being used for electro polish development so the equipment is in place to use for small quick batch process of passivation.
Are the volume % based upon 100% Nitric Acid or are they in ratio to the commercial available 70% solution you purchase from the distributor?
Eric Harmonymedical instruments - Woburn, Massachusetts
QQ-P-35C can still be freely downloaded [not verified, the site was down] at the Defense Department's ASSIST site (http://assist2.daps.dla.mil/quicksearch/). When last checked, it was identical to SAE's QQ-P-35 [link is to spec at TechStreet].
The volumetric concentrations are based upon the use of 67 wt% HNO3, Technical Grade Nitric Acid (not 70 % reagent grade). Same for ASTM ASTM A380 [link is to spec at TechStreet] & A967.
Ken Vlach - Goleta, California |
Both the DOD QQ-P-35C [link is to spec at TechStreet] and the AMS-QQ-P-35 [link is to spec at TechStreet] have been canceled and are no longer specifications to be used for passivation.
QQ-P-35c is replaced by ASTM A-967 except for aerospace, which should use AMS-2700 [link is to spec at TechStreet]B (replacement for AMS QQ-P-35).
Commercial citric acid formulations are an alternative to the nitric formulations.
Lee Kremer Stellar Solutions, Inc. McHenry, Illinois |
I just checked for the latest revision for AMS QQ-P-35 And the SAE website is still showing Revision: MAY 1998, I can not find where this has been (Canceled and replaced with AMS 2700 B) can you please let us know where we may find this information?
Jim DentonAnodizer - Elkhart, Indiana
AMS QQ-P-35 was canceled in April of 2003 by SAE/AMS Committee B, reconfirmed in the September meeting. It was canceled in favor of AMS-2700 [link is to spec at TechStreet].
++++++ Most of my suppliers have their own standard of passivation process and they are not certain whether they conform to the AMS-2700 [link is to spec at TechStreet]B standards. What must I ensure that exist in the passivation process of my suppliers before I declare that it is within the AMS 2700B standards. Masrurah Marzuki- Singapore April 15, 2010 As others have mentioned in this thread, when QQ-P-35 was cancelled it was replaced by ASTM A 967, and by AMS-QQ-P-35 for aerospace jobs; AMS-QQ-P-35 was then replace by AMS 2700. - Madison Heights, Michigan, USA
