Letter 24019
Lacquer removal from old copper
I would like to remove lacquer from an antique piece of copper, it is very uneven and has worn off in many places. However having said that, I also do not want to disturb the patina. The piece is about 80 years old and the patina is quite nice except for this issue.
Thanks for any advice you can offer.
Timothy Jensen
- Plant City, Florida
If it actually is a lacquer some ether should take it right off. Starter, or brake fluid are both ethers. Starter fluid works best as it very quickly evaporates.
Ronald Zeeman
Continuous Colour Coat - Brampton, Ontario, Canada
Window cleaner... or straight ammonia .. it will blister right up ..rinse with water ..... so think about this .....How many things have you ruined the clear lacquer finish on in your life ?.. Do Not Clean Custom Wheels With Windex...
Jim Potterf
- Belmont, North Carolina,
Dear reader
Post an answer
Post a question
Report broken links
List of Directories
