finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 24010
Weld contamination with grinding media
Hi, our company is recently manufacturing Inconel 625 tubes that later will be TIG welded with the end fittings. Due to pretty tight tolerances on tube end squareness and perpendicularity, we grind the ends using surface finishing wheels. The concern is aluminum oxide contamination of tube edge resulted from grinding. Will it significantly effect the future weld? If yes, is it safer to use silicon carbide or another type of abrasive?
Ed Voychuk
tubing assemblies mfgr. - Elmwood Park, New Jersey
If you have any concerns regarding alum oxide cross contamination, then don't do it. A lot depends on the amount of material to be removed, the pressure used to remove that material and the actual tool/ grinding wheel. Silicon carbide is normally recommended for materials to be welded.
AF Kenton
Huntingdon Valley, Pennsylvania
It absolutely will effect the weld as the puddle temperature is high enough to vaporize the Aluminum Oxide. Electron beam welds looked terrible under magnification in the met lab. Use silicon carbide with no problem that I am aware of.
