HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 24006
DISCOLORATION OF BRASS WHEN SOLDERING
WHEN SOLDERING .032 BRASS TO .032 BRASS USING A 60/40 FLUX CORE SOLDER ALONG WITH STAY CLEAN SOLDERING FLUX THE BRIGHT BRASS FINISH WILL DISCOLOR TO A PATCHY REDDISH COPPER COLOR IS IT POSSIBLE TO GET THE BRASS TO SOLDER WITHOUT THE DISCOLORATION? WE USE A HIGH WATTAGE SOLDERING IRON.
THANK YOU,
ROBERT HERMAN- PORT ORANGE, FLORIDA
| December 27, 2008
Sounds like you are burning or etching away the zinc in the alloy. - Menomonie, Wisconsin |
July 31, 2009
Is there a way to remove the copper that has come to the surface after soldering brass?
Jann Greenland- Little Rock, Arkansas
March 6, 2011
Hi. I'm not sure if it's practical to actually remove the excess copper, but it it possible to bright dip the brass to get it back to a nice color. Many types of bright dip are available, but the most popular is probably the proprietary sulfuric acid + hydrogen peroxide formulations. I'd suggest asking a plating shop to do a sample, as that way you won't have to learn everything all at the same time :-)
