HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 24000
Electrolizing of water into hydrogen and oxygen
Hello,
Please I wonder how can we separate water components into hydrogen and oxygen.
Thanx,
Abraham H. [last name deleted for privacy by Editor]univ. student - Amman, Jordan
I suggest to use very, very. very, very, very small tweezers to separate the atoms. (grin)
George Gorecki- Naperville, Illinois
S |
Try electrolysis.
+++ You need a source of dc electricity, such as a car battery, a set of inert electrodes, such as copper. Connect a piece of copper to each terminal on the battery and put their other ends into the water. Gas will come off the ends of the both copper wires. The anode (+ve pole) produces oxygen and the cathode (-ve pole) hydrogen. Do not let the two loose ends of the wires ever touch each other!
| March 6, 2011 Hi, Cousin Abraham. Trevor's advice is fine, but the water must conduct electricity fairly well to allow the electrolysis current to flow at a good rate. Adding salt to the water is one way to do that, but to avoid concern about the possible generation of chlorine gas, it is best to use a salt which is not chlorine based. Sodium sulphate is fine, epsom salt (magnesium sulphate is fine), a bit of vinegar would help too. Please look up Faraday's Law of Electrolysis and you will find that there is a specific relationship between how much current flows and how much hydrogen and oxygen will be evolved. One "Faraday", i.e., 96500 ampere-seconds, will release one gram equivalent weight. Best of luck with the project. Regards,
