finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 23083
Bench-top blackening of aluminum alloy
Part of a medical product I'm working on consists of a subassembly of some aluminum alloy parts, together with optical glass fibers. I need to blacken the aluminum alloy after creating the assembly. Consequently, I need a bench-top process for blackening; preferably one that does not adhere to glass. Blackening the aluminum before assembly doesn't work because the end of the glass fiber must be polished, and this removes any finish from the surrounding metal. Any suggestions would be appreciated.
Francis Dudley
- Torrance, California, U.S.A.
If all you need is to have the aluminum look black, then there is a product called Alumablack TM [Birchwood Laboratories] that may be of help to you. If you need corrosion protection also then that product would probably not cut it. How intensive is the polishing process - Would an anodize (hard or type II) stand up to it?
Good luck,
Jim Gorsich
Accurate Anodizing Inc.
Compton, California, USA
