HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 23010
Bluing / black oxiding of welded steel
Will the welding of low alloy cast steel cause me any problems during a subsequent bluing operation. The alloy is 1020 cast steel.
Shawn [last name deleted for privacy by Editor]- Ephrata, Pennsylvania, USA
December 10, 2011
Hi, Shawn.
Bluing / black oxiding is a conversion process rather than a coating process. That means that the base metal reacts with the process chemicals, and the reaction products consequently depend upon the base metal as well as the process chemicals. Such processes cannot be expected to offer the same surface finish when the base metal varies.
I would not say that it is necessarily impossible to get satisfactory results, but you should expect different results in the weld areas that will require effort to solve.
Readers: This site is made available for camaraderie & technical info exchange by our supporting advertisers, and they will contact the inquirer privately regarding their commercial needs. Please offer comments on any technical issues, but not sourcing suggestions or testimonials. Thanks!
