HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 23000
Mechanical plating equipment, solutions, services
+++We introduce ourselves as a major sheet metal parts manufacturer in India. We understand that you are into plating solutions. We are interested in setting up Mechanical Plating & Galvanizing facilities in India. There is a good scope for such plating & Galvanizing process in India. Our own volume of plating is 1000 kg a day and lots of opportunity available for other outsourced job work.
We look forward to your co-operation and tie-up in following manner :
1. We have requirement of a second hand plant for the above process in working condition.
2. We would like to tie-up with a plating or surface finishing company in this field and set up such a plant in India on association basis with Technical backup
3. We would like to buy a second hand plant and seek technical consultancy (on paid basis) in India.
4. We would like to know from where we can get the raw material and other solutions for the above process.
5. We would like to know from where we can get a second hand plant.
We look forward to your association in any of the above manner. Please send us your profile and contact details to proceed ahead in the matter.
Thanking You, Yours Faithfully,
Pankaj S [last name deleted for privacy by Editor]- Mumbai, Maharashtra, India
^- Sorry! This RFQ is outdated -^
Ed. note: the banner at top will lead you to suppliers, Pankaj, or visit our "Classifieds" directory for used equipment. Good luck.
Hi, does anyone know the process called "Almac mechanical plating"? Is it a mechanical plating process with Aluminum? Is there any substitute process for it? I saw such a process on the engineering drawings but I didn't think that I can find a supplier to apply such a process in my country. Please provide me your comments. Thanks.
Charles Chan- Taipei,Taiwan
Hi, Charles
Almac is a brand name for a proprietary mechanical plating of a mix of zinc and aluminum. It was a Macdermid product a while ago, but I am not sure whether they have spun it off. Please contact them about it. Good luck.
We need urgently a source who can do Zinc 70% Tin 30% Mechanical Plating on Latch Parts (a safety related item and hence do not wish to go for conventional Electroplating which has the problem HDM. Per day plating requirement is around 500 kgs. We prefer the source to be in Bangalore or can somebody willing to set up this project at our cost near our location as our Captive unit.
JAYARAMAN CAutomotive Components supplier - BANGALORE, KARNATAKA, INDIA
Saify Ind is a large plating enterprise in Bangalore which offers mechanical plating and is a supporting advertiser of finishing.com, Jayaraman. Good luck.
October 30, 2010
We are manufacturing automobile parts for OEM's in India and Europe.
For European customers, require mechanical plating instead of zinc electro deposition coating.
We are searching for suppliers who can support us and willing to put a plant in Chennai, near to our Factory. ie near to Hyundai motors limited, sipcot indl area, chennai.
If any interested, please call me or drop your email.
Thanks & Regards,
Bhavanishankar Pai
product designer - Chennai, Tamil Nadu, India
