HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 22078
Plasma Nitriding
Hello, I am a product engineer in Auto ancillary manufacturing unit. I would like to know the process of Plasma Nitriding, which is said to give wear resistance. Is there any difference between salt bath nitriding and plasma nitriding?
SENTHILKUMAR- CHENNAI, TAMILNADU, INDIA
There is a very major difference between salt bath nitriding and plasma nitriding. In salt bath nitriding, the component(s) are placed in a molten salt bath and the entire component it heated to get a hard nitride layer on the surface. In plasma nitriding the nitride ion is bombarded on the component at much lower temperature to achieve the same end. The component is not heated to the same extent. The hardening is more uniform and the depth can be controlled to much better accuracies. The equipment is exponentially expensive and since the coating is done in a vacuum chamber, you cannot do it on all components economically. Typically, this is done by job coaters only since a single industrial entity is not able to justify the investment for in-house production.
Hi Gurvin, |
Max Babi
- Chennai, Tamil Nadu, India
September 7, 2008
Respected Sir,
I am student of tarbiat modares university of Iran(tmu) doing project of plasma NITRIDING OF h11 STEELS
So sir please send me some notes and how to establish the process.
Thanking you sir, waiting for your mail.
student - Tehran, Iran
February 7, 2012
Dear Sir
H11 material is suitable for Plasma Ion Nitriding
We do usually 250 Microns depth and we will achieve 1200 Hv at 100 g load
It is the best process for hot forging application.
- Tamil Nadu, India
