finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 22022
Automotive Alusil block piston coating solution request
I am looking for a piston coating solution that will allow me to run forged aluminum pistons in my Alusil block Porsche 928. Only cast aluminum pistons (iron/tin plated) are available. Cast piston strength does not meet my needs. I must have custom forged aluminum pistons manufactured for this application.
Solution must be durable (current cast aluminum pistons with iron/tin plating typically last several hundred thousand miles of service with proper engine maintenance).
Does anyone know of a ceramic coating solution, if so, where I can purchase it?
(I understand that the iron/tin plating process is not appropriate with forged aluminum pistons.)
Daniel A. Perez
- Buckland, Surrey, UK
I'm curious to see what ceramic options are available. But correct me if I'm wrong but doesn't the 944 turbo utilize forged pistons with the factory "Tin" coating?
Mark Whitesell
- Hillsboro, Oregon, USA
