finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 22020
Cleaning a military bronze cemetery plaque
I'd like to know how to clean a bronze military plaque that has been in the cemetery for about 11 years. We've tried polishing it over the years and it now looks very dull. One of the products we've tried is Brasso [linked by editor to product info at Amazon] which apparently added to the dullness of the stone.
Sandy K [last name deleted for privacy by Editor]
- Bay City, Michigan
Hi:
I have the same question for a bronze war memorial in Gustine, CA. Did you get an answer to your question and did it work?
Thank for any help.
Diana B [last name deleted for privacy by Editor]
- Sacramento, California
I too am searching for advice on the best way to clean, brighten up, a bronze historic plaque placed in the 1920s on an outdoor boulder. Last year it was hit by a black paint ball which we washed off with detergent and water. The appearance is very dull and dingy.
E K Johnson
- Easton, New York
I wish to clean a 12" x 24" nameplate that was cast in bronze. It has raised letters and a smooth background and has weathered over time to an almost black shade of coloring overall. The nameplate is affixed to a stone pillar and will most likely have to be cleaned while still in place. After cleaning, I would like to protect the finish to prevent it from turning black again. I would appreciate your advice. (This letter seems to already ask a similar question, but I cannot locate the responses.) Thanks very much.
Bill C [last name deleted for privacy by Editor]
Retired Do-gooder - Wethersfield, Connecticut
S
I
D
E
B
A
R
It's a public forum, Bill, so more people ask their own questions than answer someone else's :-)
You'll sometimes find unanswered questions, but if you spend some time with the site's search engine, you'll almost always find that a similar question has been answered well.
finishing.com
Brick, New Jersey
I NEED TO FIND SOME CLEANER THAT WILL CLEAN MY WIFE'S BRONZE MARKER.
LEONARD C [last name deleted for privacy by Editor]
- DOUGLASVILLE, Georgia
Most plaques and markers come with a clear lacquer finish, this only slows down the oxidation process and after some time depending on the exposure you have to refinish the bronze to maintain the original look...so here we go.
If you have raised letters and trim and you are ok with a satin grained look, the you can sand in uniform direction to remove the clear coat, as you are doing this you will notice it is also cleaning and removing the oxidation.
If you have a recessed background color use caution not to damage the color, once you are done sanding and have done your detail work and are satisfied with the look...Now you can spray on a clear finish coat with a UV inhibitor.
VERY IMPORTANT
Don't touch the bronze after you clean, you have acid and oil's on your hands and this will leave finger prints that will show up in a couple of weeks.
Have Fun
Mark Rekdahl
- Los Angeles, California
Yes I would like to know how to clean the bronze plaque that my dad has on his grave.
Tom H [last name deleted for privacy by Editor]
- Fowler, Michigan
Hello I would like to know what is the best way to keep a bronze plaque in good condition? We would love to keep my daughters bronze plaque at the cemetery looking its best.
Thank you in advance for your help!
Ana M [last name deleted for privacy by Editor]
- Dallas, Texas
General Purpose Bronze Cleaner: Salt, Vinegar, and Flour. Dissolve 1 teaspoon salt in 1 cup white vinegar. Add enough flour to make a paste. Apply paste to bronze and let sit for 15 minutes to 1 hour. Rinse with clean, warm water, and polish dry.
Dr Gayle Kite
- lake worth Florida
June 8, 2008
You can also gently rub it clean with a cloth dipped in mineral spirits [linked by editor to product info at Amazon].
If using the vinegar/water/flour method, make sure the water you are using is warm DISTILLED water.
Joan Martin
- APO, AE
February 10, 2009
My late wife's bronze headstone needs refinishing, I used the wrong cleaners on it and it needs refinishing real bad, I am 70 and wont be long before I will be beside her and I want to get it looking good again, thanks
leonard cronan
- douglasville, Georgia
January 16, 2012
Just read this post and in the event that you have not found an answer here it goes. As posted in one of the responses most all these signs or plaques have come with a lacquer coating or even tougher some sort of a urethane applied at production.
If you have a plaque that is completely bronze color then you have a fewer steps. If a lacquer coating you can use acetone or any other stripper to remove the lacquer (please note always be careful and follow instructions on how to handle any product), then you can clean the bronze with some oxalic acid which is a whitener or bleaching agent that will remove the patina that has occurred on the plaque. I usually mix the oxalic with some neutral soap as an additional cleaning agent. Rinse thoroughly with water and if needed you can use a white scotch pad for any stubborn marks as long as you go with the grain. Then lacquer using one of the products supplied by our many advertisers on this site. The only curve ball would be if the background is a painted finish such as a brown color usually. If this is the case when you finish cleaning spray the plaque with the brown color and then you can wipe the face of the letters before the paint starts to dry leaving the brown only in the recessed areas (try wrapping a piece of some stiff wood or 6in scraper in the towel and pulling it across the face of letters for best results)Then clear coat the whole plaque
Hope it helps
Bill McKenna
Metal Finisher - New York, New York
