HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 22011
ASSURING STEEL IS UNPASSIVATED
1. I AM USING GALVANIZED STEEL, I WANT TO TAKE OFF THE PASSIVATION, WHAT PRODUCT SHOULD I USE?
2. IS THERE A TESTING METHOD TO MAKE SURE THE METAL IS UN-PASSIVATED?
THANK YOU,
SERGE DORE- GRANBY, QUEBEC, CANADA
The meaning of the word "passivation" is very tricky in this instance. Generally the term "passivation" is applied to stainless steels, and refers to the building of a chrome-rich surface skin. The term "passivation" is also sometimes used, however, to refer to the chromate conversion coating that is applied to zinc plated and zinc galvanized surfaces. But the way you are using the term, it seems like you are really asking how to remove the zinc, not just the chromate?
The zinc will almost instantly dissolve in hydrochloric acid; in fact the reaction can be violent.
If you are trying to remove just the chromate conversion coating, I think scrubbing it with trisodium phosphate [linked by editor to product info at Amazon] and Pumice [linked by editor to product info at Amazon] will do it. There are ASTM standard "spot tests" for the presence of the chromate.
