finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 22007
Brass protection
Is it OK to spray lacquer on brass to keep it from tarnishing? If not, is there some other coating I could use for the same purpose?
Pat W [last name deleted for privacy by Editor]
- Oakland, California, USA
Pat,
I am also interested in knowing if I can use a lacquer on my old brass lanterns that are on either side of my front door. Can you tell me what you have found out about this.
Mimi N [last name deleted for privacy by Editor]
- Charleston, South Carolina
Yes, that's what brass lacquer is for. You can find out more about the technology of brass lacquers from G.J. Nikolas, and people should contact them for industrial quantities of brass lacquer.
For small quantities for home use, you could buy a spray can of brass lacquer [linked by editor to product info at Amazon]. Good luck with it!
finishing.com
Brick, New Jersey
March 17, 2008
Recently purchased two outdoor brass light fixtures; want to keep that nice shiny look. Would some water-based acrylic sealer work just as well as the "Brass Lacquer" mentioned in the earlier post?
Sophia Schmidt
- Gaithersburg, Maryland
March , 2008
Hi, Sophia. Acrylic sealer might work okay. The principal advantage of brass lacquer is probably the ease of removal with lacquer thinner [linked by editor to product info at Amazon] or acetone [linked by editor to product info at Rockler]. If you put acrylic sealer on and it starts fading or chipping, or the brass starts tarnishing in areas, it's not easy to redo.
finishing.com
Brick, New Jersey
