HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 22006
Re-nickel a drum in black, saving the engraving
I own a 1920's Ludwig snare drum that's called a "Black Beauty". It has a brass shell which was then nickeled in black then engraved exposing the brass. All the hardware on this drum is in copper. A beautiful drum. My problem is someone removed the black nickel and what I have now is an engraved brass shell. Is there a way that I can have it electroplated in black nickel and not damage the engraving or cover it? Also, I was told that the prep, the buffing of the shell may remove some or all of the engraving. Any suggestions would be greatly appreciated.
Michael Guedes- Monroe, New York, United States
It is possible to replate a drum and to save the engraving at the same time!
Adrian KirchlerAK drums - Olang, ITALY
Hi Michael,
You could re-plate the drum, but you can not save the engraving, per se'. Preparing the shell would require buffing the metal shell to a high luster. This will give you the shine you want out of the finish. After plating the shell, you might contract John Aldridge of "Not So Modern Drummer" to engrave over the existing pattern. That is the best approach, next to leaving the drum in it's original state.
Sincerely,
Curt- Castle Rock, Colorado, USA
...and I tell you - it is possible (..take a look at my website ak-drums.com under "restoration")
- Olang, Italy
