finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 21047
Treating galvanized steel sheets to avoid white rust
Hello,
Can anybody help in finding solution for treatment of galvanized steel sheets against white corrosion. The sheets are exposed to very humid conditions. I am looking for a treatment which can give prolonged protection without paints. Any suggestion is highly appreciated.
Thanking you,
Ramchander Gegula
- Hyderabad, Andhrapradesh, India
You are already chromating these galvanized sheets?
finishing.com
Brick, New Jersey
Hi,
Hope you have chromate treatment facilities there in your process. Keep chromate solution temperature above 80 degree centrigrade to dry up the sheet after chromate treatment, next you can use hot air to dry up the sheet after treatment. Corrugate the sheets as soon as possible in the humid condition.Arrange cross ventilation during storage--if necessary use pedestal fan at the storage area.Last of all if the condition does not improve your last resort would be to use oil in the corrugation machine (through special arrangement), which may help you to beat white rust formation.
Mahbub Hossain
- Dhaka, Bangladesh
Chromating unit is surely a good solution to prevent Galvanised sheet from white rust formation. But chromic acid is another factor which can arise problem of pollution.
Please suggest whether this problem can be minimised by using chemical coaters? If yes, can coating by chemical coater avoid the use of cleaning section in Color coating line?
Please explain the merits and demerits of this alternative.
tks,
Sunil Chauhan
- Indore, M.P, India
During a panel discussion at Sur/Fin 2006 in Milwaukee, one of the participants claimed that the TCP hexavalent-free chromate conversion coatings developed for aluminum work well on galvanized materials as well. I would suggest that you contact one of the four licensees for further discussion. They are Henkel, Luster-On, Metalast, and Surtec.
finishing.com
Brick, New Jersey
