Letter 20838
Unable to meet Boron discharge level
Boron discharge std, 4 mg/ml Std B is too strict. Malaysian std B
for boron is 4 mg/ml. My waste water can only come down to 30 mg/ml.
I have tried many tricks and waste water consultant however, non of
it is successful. Can you advise if the 4 mg/ml is an impossible
standard, that it is impossible to reach? What is the Boron discharge
level for US, UK or EU?
Tan, SF
- Penang, Malaysia
There are very few ways to remove boron from water to low
concentrations. If you cannot find an alternative chemistry that does
not contain boron,one way to remove boron is by a selective ion
exchange resin with n-glucamine functional groups. This resin can
remove boron to less than 1 mg/l. However, the resin is very
expensive and has a low capacity before it becomes exhausted and must
be regenerated.
In most cases, it is preferable to go to the source of the boron,
and put in some kind of closed-loop recycling system. Even if there
is a waste from this system, it will be a small volume with a high
concentration, so even if you can only treat it down to 30 mg/l,
there may be enough other dilution water to allow you to meet the 4
mg/l limit.
There are no USEPA limits for boron, but there are State and local
limits in many parts of the country. Some of these are as low as 1
mg/l.
Good luck in finding a solution to your problem.
Lyle Kirman
water treatment systems - Cleveland, Ohio
Can you help us to find the way about 1000 mg/l b as boric acid in
the waste water?
And the limit is 1 mg/l only.
We can even invite your engineer come here and teach everything.
We are an environmental engineering company in Taiwan.
Best wish
Wang Chuan Hsin
- Taiwan
Ed. note: Readers who wish to answer, please do so. Readers who are
looking for answers please see our
FAQ on waste water treatments for
boron. It lists the more than 20 threads on this topic that are
on line here.
Dear Reader, please --
- Answer or follow-up on this
subject (in non-commercial
fashion).
- I want the contact information to
reach
the inquirer privately.
- Post a
new question or inquiry on a
different subject.
