![]() Cycles thru suppliers. |
Letter 20095
To answer your question, Electroless nickel is a non hazardous material. However, it is always better to recycle/reuse than to dispose of any substance. Nickel is definitely a recyclable substance.
Cynthia Smith
- Pottsville, PA
While electroless nickel is non hazardous, electroless nickel solution is absolutely, positively, a regulated metal. You can not sewer it and you can not dump it on the ground. The chelators in it will cause problems in your conventional wastewater system also.
Yes, electroless nickel is recyleable, Cynthia, and some vendors will take it back. But I have to disagree with you about it being non-hazardous because it is my understanding that all waste from a plating shop is categorically hazardous waste; i.e., because it is plating waste, it is hazardous by statute regardless of what is in it.
Ted Mooney finishing.com Brick, New Jersey |
Save
This Page (why?) - Home - ©1995-2009 finishing.com
