HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 20074
Inhibitors for hydrochloric acid
+++Dear sir,
What are the best quality inhibitor that is used for hydrochloric acid in case of hot rolled coil pickling and also the best suitable anti-fuming agents? I will be grateful to you if you can reply at your earliest convenience as early as possible.
Thanking you,
B.N. Srivastava- Jamshedpur
I have used Armohib 28 supplied by Akzo. Hydrochloric acid containing a percent does not attack steels. If you do not find the company in your area you could try Holland or the UK. Nick
Nick Clatworthy- Hastings, UK
