finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 20009
Seawater corrosion of type 304 stainless coolant piping
We have experienced a problem with a customers coolant piping on offshore units. The cooling circulates fresh sea-water through a cooler to provide engine, fuel, and air cooling. The stainless steel piping has started to corrode and leak at the welded joints. 304 stainless was used for material in the piping and elbows. Is this a form of Galvanic corrosion?
R. Reder
- Calgary, Alberta, Canada
Hi !
You are not the first nor will you ever be anywhere like the last to have problems with stainless in salt water. It keeps and KEEPS coming up.
And you used a mere 304 series, tut, tut. Even 316 has problems. Go the archives and see, I think, # 8544, 7117, 16942 and recently "6a" # 19760
Why in the HECK don't knowledgeable (?) engineers use the right damn plastics to avoid marine corrosion!
Freeman Newton - White Rock, British Columbia, Canada
Ed. note:
Please keep Freeman in your thoughts
& prayers.
Message from Freeman, Dec. 2010
It sounds like it might be a welding problem. If you don't weld SS properly, you get carbide precipitation around the welds. You've then got some prime spots for corrosion. I was saw a customer's process tank almost literally fall apart because of bad welding. I'm no welding expert, but I have heard that 304 is not the greatest for welding. People usually recommend 316L.
Christian M. Restifo
- Pittsburgh, Pennsylvania
