finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 20006
Aluminum corrosion by DI water
Have recently encountered problems regarding aluminum bond pads (in a chip), being eaten up by just pure dipping for 30 minutes to 1 hour in just pure DI water. Didn't think pure water can erode or etch. Anybody has explanation or answer?
Aubert Escio
- Chandler, Arizona
DI water, because of the high free Hydrogen ion concentration is VERY corrosive. DI water is so corrosive it cannot be used in iron pipes, and will certainly tear into aluminum. Try distilled water.
Editor's note:
   Mr. Probert is the
   author of
I hope you have found an answer to your problem, since it has been over a year. But I was reading and I have the answer. Your problem is a very common phenomenon in the semiconductor industry. Even though they use DI water in their process they have to inject CO2 to bring the resistivity of water down. This way the DI water is not corrosive and will not harm your metallization. This problem of metal etch will cause reliability problem for the device and potentially bonding problems.
Hope this helps.
Eric Prinz
- Morgan Hill, California
I am looking for topics on corrosion of aluminum copper leads with TiN in DI water. This is a problem during the water rinse after solvent clean. In fact I am looking for information of this affect with pH of DI water.
Allen Page
Semiconductor - Richardson, Texas
