HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 19038
Big Dink Racing
I like your advise it seems that you have a good grasp on whats good and whats too much. My question is that you say to use 400 and then proceed directly to a compound and not a polish. Is there a compound that you recommend and also do you have some advise on proceeding with the ruff aluminum in the center of the mag. I know that the outer part of the rims is basically smooth already but the centers are cast would you recommend hand sanding or a type of sandblasting. Your help would be appreciated I just got a quote for full polishing and it was a $1000 dollars for both tires!
Great tips guys keep it coming!
Mike Kaiser- Calgary, Alberta
