Letter 18095 Defective nickel-chromium plating [Malaysia]++ I work in a consumer product manufacturing plant. Recently, we receive defective nickel-chromium plating part from our supplier. From the attach photo you can see some wrinkle mark on the chrome layer which happen after go thru -20C low temperature preservation test. The composition is ABS plastic with nickel-chromium plating. Looks like it is always more severe near the mould injection gate point. Our supplier until now still does not have any clue to why it happen. I would like to know what might be causing this problem. Thank you. ST LEE
++ This looks like delamination caused by poor adhesion of the metal to the ABS; thermal cycling will really show up the problem! It is interesting it is associated with the mould injection gate, as this could indicate its cause; I am no moulding expert but have seen a very similar problem before and found it to be incorrect moulding conditions. I suggest you peel off the metal and look at the ABS underneath. It is possible you will find evidence of chromic acid in the ABS; this can easily be blamed on bad rinsing, but in my experience it is also associated with bad processing. Metal Finishing Guidebook [link is to book review/sourcing on finishing.com]
Dear Reader: please choose what you want to do.
Save
