HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 18091
Polypropylene Cooling Coils
Dear Sirs,
We are Turnkey Paint Plant Suppliers and are presently working on Autophoretic conversion coating plant.As per Henkel's( chemical supplier) recommendations only PP coil are allowed for the cooling of chemical bath.I would like to know the heat transfer rate per unit area in PP coils, when my chilled water is circulated at 5 deg C & 10 deg C respectively. The chemical bath needs to be maintained at 18 deg C.
KANTHA KUMARLeo Surface Coatings Pvt. Ltd. - PUNE, MAHARASHTRA, INDIA
Hi Kanthar,
What about trying to get this information from Fischer (actually, I think it's Fischer, AG) who make cooling coils both in PP and in PVDF. Obviously the heat transfer is not nearly as good as a metal one ...
| Freeman Newton - White Rock, British Columbia, Canada | Ed. note: Please keep Freeman in your thoughts & prayers. Message from Freeman, Dec. 2010 |
